Mojave Torque Specs
Old Apr 15, 2005 | 02:17 AM
Zebra's Avatar
Default Mojave Torque Specs
Can someone tell me the engine torque specs when reassembling the engine? The one I can think of that I will need are:
Case bolts
Cover bolts (mag and clutch)
Clutch basket
Flywheel
Counterbalancer gear
Head bolts
Cylinder bolts
Valve cover bolts
Anything else?
Or if someone could scan the torque spec page and scan or email (chrisaparker@hotmail.com) that would be awsome!
Thanks in advance. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 15, 2005 | 04:30 PM
holeshotz8436's Avatar
check out this web site and give the guy a call. He knows just about everytihng about mojaves and lakotas. www.cycleworksracing.com the phone 717 637 1907
Old Apr 15, 2005 | 07:50 PM
haywoodjalikme's Avatar
Case bolts= 87 in lbs
Cover bolts (mag and clutch) no specs given, just don't strip them!
Clutch basket= 87 in lbs
Flywheel= 69 ft lbs
Left side balancer gear nut= 58 ft lbs
Head bolts 6mm= 87 in lbs and 10mm= 33 ft lbs cylinder head nuts 8mm= 18 ft lbs
Cylinder bolts 6mm= 87 in lbs
Valve cover bolts= 69 in lbs
Water pump impeller nut= 69 in lbs
Camshaft bearing cap bols=104 in lbs
Camshaft sprocket bolt= 29 ft lbs
Hope this helps
Jeff
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
raman8tor
Sep 20, 2015 07:35 AM
