new clutch spring for the V
Old Mar 14, 2005 | 04:49 AM
Budwsr's Avatar
Default new clutch spring for the V
so can I get a new clutch spring and nothing else or is it advised to get the weights and clutch cover etc.?
also I ride allot in the mountains and some inthe dunes i like the stock spring what is comparable to that
I know allot of people are going withe the orange/blue one anyone ride in the monatins that has this mod?
if so how ya like it and what spring ya got?
Old Mar 14, 2005 | 11:05 AM
schl48a's Avatar
do a search for pink spring and get that.
Old Mar 14, 2005 | 01:51 PM
Kawierider's Avatar
I've been running the orange/blue spring by itself with no problem. I just installed the Dalton weights, but haven't ridden it yet. The heavier weights should bring the RPMs down a little by accelerating the shift-out.
Old Mar 14, 2005 | 07:29 PM
Budwsr's Avatar
what's the difference between the pink and the orange/blue?
will i see a significant change if I just chang eout the spring?
Old Apr 15, 2005 | 03:15 AM
ManicHaze's Avatar
the Pink spring has basically no stall at all. So it is very much like the stock spring on the low end. The Orange/Blue has a fair amount of stall. They both have essentially the same shiftout though. So in otherwords, the orange/blue is like a pink with some stall. The stall will effect rideability a little, but the Orange/blue spring doesnt have quite enough stall to be a problem on tight trails. It comes down to personal preference.
As far as noticeable change goes, we put an EPI bright green (about the same stall as the orange/blue) in my dad's prarie, and it turned it into even more of a wheely machine because of the stall. If you want a little more wheely ability, go with a spring with more stall. Since you have it piped, and once you get the jetting ironed out. Id go with the Orange/blue, thats just from my research. i have never tried one, but that is the spring i'm going to get when i pipe my V. I dont think the stall will be too hard to manage after a little time to get used to it. but again, thats rider preference.
I'm picking my V up this saturday. I have an EPI red spring i'm going to put in it. so i can let you know how that goes
Old Apr 15, 2005 | 04:58 AM
bassetboy55's Avatar
what exactly do the springs do? i would hate to have a stall. i ride trails alot and some log roads. minimal drag racing.
Old Apr 15, 2005 | 01:14 PM
ManicHaze's Avatar
I can try and explain it but you would be better off looking here: www.700v.com they have a FAQ section that tells alot about the springs.
Old Apr 15, 2005 | 08:36 PM
perfect. thanks
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
