250x problems need answered
Old Apr 16, 2005 | 12:30 AM
91250xHahaha's Avatar
Default 250x problems need answered
Ok i ride a 250x and when i ride wheelies on the street... i see little lines of gas behind me n when i park u can always smell gas around my quad, whats this?? Where could i be leaking?? And i know water isnt good but sometimes u have to go through it and if water comes a couple inches above the frame i die even when im still going strong am i getting water in somewhere? if anyone could help me out i would greatly appreciate it!
Old Apr 16, 2005 | 01:15 AM
2fun's Avatar
I don't know if this is normal or not (don't remember having lines of gas when I rode wheelies on our 250X), but it sounds like you are getting too much fuel flowing into the carb while the front end is in the air, thereby flooding the bowl and causing overflow.
Try checking the float height and make sure it is properly set.
The water thing, I have no idea about.
Old Apr 16, 2005 | 03:52 PM
87250xman's Avatar
Check your fuel line and your carb. You might need a line or a rebuild.
Old Apr 16, 2005 | 04:27 PM
NLWarrior01's Avatar
First off .. you shouldn't be riding wheelies in the street .. that'll get you more trouble than a leaking carbeurator.
The gas is most likely coming from your overflow hose because of the angle of the quad ... and it may end up sticking a bit or pooling up on your frame to drip off after you have stopped, which is why you can smell is strongly even after you have stopped riding.
I have no clue about the water either .. that seems really weird unless by "a couple inches above the frame" you mean up to the seat .???
Old Apr 16, 2005 | 05:20 PM
87250xman's Avatar
I do wheelies on mine all the time and it never leaked.
Old Apr 17, 2005 | 05:54 PM
1988fast250x's Avatar
Hey I had the same problem with my 1988 250x and i rebuilt it and it still dont it so I went and bought a new one if you aregoing to do this for a stock one witch u pretty much have i would go witha 32mm mikuni flat slide there great. It might run alittle different like boging alittle when you first get if you keep on the rpms it will do just fine. on the stock carb there is an accelorator pump pushing gas in to the motor with the flat slide its sucking the gas out of it.
1988 250x
big bore kit
VP race fuel
proformance cam (great)
proformance valves
ported and poliched
uni air filter
new timing chain
ITP holeshot tires
AC nerf bars
34mm mikuni carb
lone str axle carrier
FMF mega max pipe
fly handle bars
AC grab bar
13:1 compression
14 tooth front sprocket ( never happier with it)
Mods coming soon
( lonestar axle +2 with hubs)
( Lonstar stearing system)
( DG front bumper)
RIGHT BESIDE THE STOCK 400EX
Old Apr 17, 2005 | 08:49 PM
hondaguy2's Avatar
The gas coming out is normal, the float opens up and then the fourwheeler gets too much gas and at that angle it will run out. The water issue i have had too. There is a splash guard its call above the shocks under the front headlight. If urs doesnt have it a small puddle will cause water to splash through the intake tubes on the frame and get in the airbox. All the splash gaurd is, is a plastic piece with rubber flaps on the back ,so if it isnt on u probably put it on.
Old Apr 18, 2005 | 09:37 AM
iwannaride2's Avatar
gas....overflow hose mine does the same thing...
Firefighter400
Oct 8, 2022 06:38 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
