i need rear axel bearings
hi guys i just got a quad and the rear axel bearings are wasted . but they welded on the left hub i think the has to slide out to put in the bearings ? maybe some one knows here its a 1990 350 moto 4 ymf350er
You will have to remove the left hub...Then Take off the 2 nuts that hold the sprocket hub on and remove it from the axel....
You have to take the brake caliper off and then remove the axel....You will have to drive the axel out to the right....
If it is welded on you are in for a lot of work tring to get it off..You will have to grind the weld off to remove the axel.....
GOOD LUCK
GOOD LUCK
