i need rear axel bearings
Old Apr 16, 2005 | 11:25 PM
roger75's Avatar
Default i need rear axel bearings
hi guys i just got a quad and the rear axel bearings are wasted . but they welded on the left hub i think the has to slide out to put in the bearings ? maybe some one knows here its a 1990 350 moto 4 ymf350er
Old Apr 17, 2005 | 01:38 AM
TRLYFZ450's Avatar
You will have to remove the left hub...Then Take off the 2 nuts that hold the sprocket hub on and remove it from the axel....
You have to take the brake caliper off and then remove the axel....You will have to drive the axel out to the right....
If it is welded on you are in for a lot of work tring to get it off..You will have to grind the weld off to remove the axel.....
GOOD LUCK
Old Apr 17, 2005 | 01:40 AM
TrailBlazerguy250's Avatar
they arnt chain are thry ?
Old Apr 17, 2005 | 01:42 AM
roger75's Avatar
ya thats what i thout i gess ill grind ther weld off and reweld it . i cant aford a new axel now lol
thanks for the help
Old Apr 17, 2005 | 01:43 AM
roger75's Avatar
no its shaft drive
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
