Brute Force 750 belt slipping?
Old Apr 17, 2005 | 08:56 PM
JPBabyRange47's Avatar
Default Brute Force 750 belt slipping?
I just got my Brute Force last week ( 5 hrs on it now) and was trying to pull a dead tree stump- something that my friends Grizzly wouldnt have a problem with on a bad day- and when I would get the winch cable tight and pull on it in reverse, the tires wouldnt spin, the engine would just rev and it felt like something was wrong. I think its the belt also, because I see on here how everybody pulls wheelies so easy and I cant get it off the ground- (I do have 27" Tires though) What does this sound like to ya'll?
Old Apr 17, 2005 | 09:06 PM
Theshonk's Avatar
Maybe rev limiter, or reverse is geared to high compared to the Yam A Hammer. Did you smell rubber?
Shonk
Old Apr 17, 2005 | 09:15 PM
No I didnt smell anything- it was more like it wasnt getting any power to the wheels- When the grizzy trys to pull something that is to heavy for it, it spins the tires (27 ITP's)
I know that this stump wasnt to heavy for the Brute but it wont even spin the tires when its trying to pull
Old Apr 17, 2005 | 10:07 PM
brutemike's Avatar
sounds like belt slip to me. I have had some recently with out the rubber smell.
to the point the belt like has come on. 238 hrs. i guess it should be worn out. I pulled the cover
off today, belt looked good. So I put the cover back on and now the rev limiter is on, the belt
light blinks and i'm frustrated.
Old Apr 18, 2005 | 11:09 AM
tuffEnuf's Avatar
JPBaby
Kawis are not intended to pull heavy loads in reverse even with reverse override. Always use low forward gear fror any heavy use or slow trail riding below 30 MPH. Same goes for wench. Lock your quads brake and use remote winch button if possible. Winch Cables are extremely dangerous & can be fatal if they break, come loose & slingshot back & hit you.[img]i/expressions/face-icon-small-sad.gif[/img]
TuffEnuff
Old Apr 18, 2005 | 02:18 PM
2005BF750's Avatar
Shonk
may be obvious, but did you push the reverse override button while backing? it wont rev up if you don't
Old Apr 18, 2005 | 10:25 PM
brutemike's Avatar
This revlimiter is activating in lo and hi forward motion. look in the broke belt forum and grizzkiller has posted the fix for resetting the computer.. pop the side cover and you will need this fix.
brutemike
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Pgbama11
Jan 16, 2016 08:19 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Pgbama11
Sep 10, 2015 08:20 AM
