spring combination's
Old Apr 18, 2005 | 04:42 PM
bubba650's Avatar
Default spring combination's
what spring's should i use after installing dynatech cdi in my 650.all i really do is mud and slow rock climbing.don't care about top end too much.already fast enough for me.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 19, 2005 | 10:48 AM
Speedwerx's Avatar
Through all of the testing that we have done we have found that the biggest bacnge for you buck is to just chnage the primary spring. We offer a coule of different rates with high engagment than the stk spring thereare kits out there for 200-300 dollars but you can get he smae perf. with a 28.00 spring. Do you have larger tires or any other mods besides the cdi box?
Old Apr 19, 2005 | 06:17 PM
bubba650's Avatar
no other mods as of yet,just the 26" 589 tires (26x12x12).the bike works ok but i just want to get rid of the throttle bog off the start.i've heard that the cdi will make it run a little cooler and smoother?
Old Apr 20, 2005 | 12:12 AM
weez440's Avatar
go with the pink primary and black secondary springs and remove 1 shim from the driven clutch and it should put you pretty close to where you wanna be might have to play with the shims a lil i think i need to take mine out and put a smaller one in.
Old Apr 20, 2005 | 10:40 AM
Speedwerx's Avatar
Ok, the cdi box makes the biggest differenace with that machine, clutchingand exhaust wil add to the performance as well. Find out what rate springs you are putting in you machine as well it always nice to know if you wnat to change somthing or if you ever have to test your springs.
Old Apr 21, 2005 | 12:09 AM
weez440's Avatar
the only reason i put in the clutch kit was to tighten up the belt and it really didn't make that big of a difference for power.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
Sep 30, 2015 01:37 AM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
Mphillips
Jul 2, 2015 07:20 PM
