Belt light stays on
Old Apr 18, 2005 | 11:01 PM
limrok's Avatar
Default Belt light stays on
..hello all..well we went toa quad rally on the weekend....there were over 600 bikes........it was a hard ride .heavy mud and water the whole way.for about 45 miles....any way my belt light came on.........and it never went into limp mode....so i figured the belt was going to go so i took my time and made it in..so today i went and gota new belt....changed it and did the failure seqence.and every thing works great............but ...guess what the belt light is still on.........and no it isnt flashing.......any ideas...thanks for the help
Old Apr 19, 2005 | 12:14 AM
weez440's Avatar
i see you got the DG3 module on it and i believe that takes care of the limp mode problem like the dynatek cdi. well did you hit 100 hours on it? it may be that you need to take the reset key and reset it. or it could be that maybe you tripped the lil switch inside the belt housing to the off position and it registers on the light but won't throw it into limp mode that is the only thing i can think of.
Old Apr 19, 2005 | 11:59 AM
limrok's Avatar
weez..the belt switch in side the cover wasnt triped... when i had the cover off .....a freind turned the key on to check the hours and it made the belt light flash so had to reset the belt indicator .but after all that the light still stays on.................still got me stumped
Old Apr 19, 2005 | 11:06 PM
limrok's Avatar
..well i figured out how to get the belt light out......u have to use a little different proceedure to do thew 100 hour ..warning to have the bike checked out...........i did it and it put the light out...only thing is it is supposed to warn ever 100 hours...and it warned at 150 this time..well any way the problem was solved.....it tells u how to do it in the service manual...page 5-23
Old Apr 19, 2005 | 11:59 PM
weez440's Avatar
thank you kawasaki for your ingenious idea with this belt indicator. at least we have the cdi's where we don't have to worry bout it but i think it is just assinine that if you are miles from home and don't have or lost the lil reset key where the limp mode kicks in even if it does when it is supposed to out in the middle of the trail and you lose all power. can't they do this same thing by just having the light illuminate to warn us of this? when your atv gets low on oil or overheats it doesn't shut it down that is what the warning lights are for. what a bunch of idiots.
Old Apr 20, 2005 | 10:14 AM
Theshonk's Avatar
Good point your honor
Shonk
Old Apr 20, 2005 | 03:12 PM
limrok's Avatar
well it only goes into limnp mode if the belt is actually breaking down and trips the switch in the clutch cover.......and the light will flash...........but..if it come on and stayes on with out flashing u can still drive it normally witch is beter than it did befor ..it flashede for me at 100 and had to take it out of limp mode..........now it only stays on.and can still ride
Old Apr 21, 2005 | 12:06 AM
weez440's Avatar
mine used to go into limp mode all the time for no reason. then i fried my dynatek cdi and somewhere along the lines my lil switch got tripped so i had to reset that. i am just saying the inconvenience of this limp mode is uneccesary
Cummins Driver
Sep 11, 2019 01:22 PM
Pahuntman
Sep 5, 2015 11:07 AM
toonces
Jul 31, 2015 09:27 AM
ScopeZ_
Jul 28, 2015 01:44 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
