400ex Throttle Problem. Help!!
Old Oct 1, 2000 | 08:57 PM
coryatver's Avatar
The thumb throttle is hard to push, like it is catching and it makes a clicking sound. I took apart the thumb throttle and everything was fine. Does anyone know what is wrong with it?
CoRyAtVeR
Old Oct 6, 2000 | 07:53 PM
coryatver's Avatar
My dad was riding it the other day and it would not move and then it broke free and now it is fine. Something is definatly messed up. What do you have to do to get the cable out of the carb?
Old Oct 6, 2000 | 09:16 PM
hot_shoe_cv's Avatar
You'll have to get into the carb & disconnect the cable from the slide, then disconnect it at the throttle.
Old Oct 7, 2000 | 02:20 PM
coryatver's Avatar
Ok thanks. I took it off. I had to take all the plastic and gas tank off to get to the carb. I don't have any cable lube so i sprayed wd40 into the cable and it is better now but it still is not right. I called all around for the part and had to order it. the cable cost $12.
Old Oct 7, 2000 | 02:58 PM
If you still have the cable out of the sheath, you might want to try to check the sheath itself for any obstruction that could be snagging the cable, since you didn't mention seeing any problems with the cable. A good grade of lithium grease, like that used in grease guns, would be good as a cable lube. WD40 has very little lubricating quality.
Old Oct 7, 2000 | 11:56 PM
coryatver's Avatar
Thank You
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Huntingdeer
Aug 23, 2015 12:06 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
