outer tie rod ends on sp500
Old Oct 1, 2000 | 09:34 PM
silverado's Avatar
where did you guys say the best place to get tie rod ends at?? i had my front tires off changing my hub oil when i noticed free play in the outer tie rod end.any help would be greatly appreciated.
Old Oct 1, 2000 | 11:06 PM
SP5004X4's Avatar
Get the new updated design from your Polaris dealer. They are a direct bolt-on replacement and are much better quality than the originals your '99 came with. I paid about $19.00 each for the new ones.
Old Oct 1, 2000 | 11:56 PM
Traildog's Avatar
Another option for you is to go to a bearing supplier and ask for Heim joints. You will need to buy 1/2" to match your tie-rod (I believe some people have been able to find 1/2" thread X 3/8" bolt hole). The bolt in the steering arm is 3/8" so you will need a sleeve to adapt it to the 1/2" hole. Another option is to drill out the steering arm to 1/2" (Not recommended). To maintain clearance when the suspension goes through its travel a small washer will need to installed between the ball of the Heim joint and the steering arm.
Also if you are a DIY kind of guy you may to look at upgrading your steering to the "easy steer" option. If you need more info let us know.
Old Oct 2, 2000 | 12:19 AM
SP5004X4's Avatar
The new design Polaris tie rods are "Heim" joints. Also the bolt hole in the steering arm is 10mm, 3/8" bolts are a little loose in it. No "sleeves" or other modifications are necessary with the Polaris part.
MikeyBoyesq
Sep 22, 2015 10:02 AM
CosmoM
Sep 21, 2015 04:57 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
jankerstien
Sep 21, 2015 03:09 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
