fan switch on the 360
Old Apr 19, 2005 | 11:37 PM
rhen74's Avatar
Default fan switch on the 360
I 've got a 03 360 4x4. The fan quit working on me recently. I tested the fan motor and it seems to be working fine. Is there a way to test the fan switch to see if that's the problem. Is this a common problem and if so is there a better solution than just replacing the fan switch.
Old Apr 20, 2005 | 01:44 PM
Hayashi's Avatar
At room temp, the fan switch should be open, >1 M ohm.
Around 153~163F, the switch should close, < 0.5 ohm, to make the circuit.
Also, check if there is 12V supply to the fan itself by measuring at the blue wire (+) of the fan and ground.
Good Luck.
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
toonces
Sep 5, 2015 01:14 PM
