why does my 250 ex shut off
Old May 3, 2005 | 09:39 PM
Guest
Guest
Posts: n/a
Default why does my 250 ex shut off
like i said before it idles all day long but as soon as you put it in gear and turn the throtle wide open it bogs down and stalls
Old May 3, 2005 | 11:13 PM
holeshotz8436's Avatar
why did you make 3 posts about the same thing?????????
Old May 4, 2005 | 12:33 AM
quicksilver's Avatar
just a guess- clogged main jet in carb. The idle goes through a different jet. Or you could have a clogged air or fuel filter, bad spark plug, bad ignition coil (cant jump spark plug gap under load, etc.)
There's a lot of things it could be. I would start with the cleaning the carb out, then check your filters. Make sure the gas tank has gas in it.
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
