Weird Idle Problem
Old May 5, 2005 | 02:02 PM
barrister1's Avatar
Default Weird Idle Problem
So my 1984 200s is running great, except for one odd problem I'm having. The idle is higher than I want it to be, to the point where it is wanting to engage the clutch at idle. If I turn down the idle using the idle adjust screw, it will slow the idle down to a certain point (which is where I have it set right now, and it's still too high) but if I turn it just a hair (even 1/16 of a turn) further, the engine dies immediately. I have good throttle response all the way from idle to redline. No backfiring, the plug looks good, and I've cleaned/soaked/blew out all the carb parts. Also, there does not appear to be any dents or divots in the throttle body slide, and it moves freely. Any suggestions? I'm stumped.
Old May 5, 2005 | 03:37 PM
RacinJason's Avatar
check for intake leaks
braaaap
Old May 12, 2005 | 06:32 PM
barrister1's Avatar
I tried spraying carb cleaner and WD-40 all over the intake end of the carb and where the carb meets the engine. Didn't notice any change in the rpms, which makes me think I have no intake leak.
Old May 12, 2005 | 10:53 PM
broook's Avatar
Sounds like a sticking choke problem.
Old May 13, 2005 | 12:00 PM
barrister1's Avatar
Don't think its a choke issue because I've got no choke cable, and I've got the choke lever wired open.
It's really odd, because, like I said before, it idles fine until I turn the throttle adjust screw even a hair, and then it just dies. May just decide to live with it.
Old May 13, 2005 | 12:13 PM
broook's Avatar
The only other thing I can think of is a plugged idle jet. Take out the jet and blow it out with air. Only poke wire through as a last resort. "SOME" of those small jets are not round inside they are star shaped to atomize the fuel and if you poke wire or tip cleaners through you could take the edge off them.
Old May 13, 2005 | 02:12 PM
ThrashAndCrash's Avatar
barrister1
Are you sure that you have the o-ring and washer in the pilot screw hole? If so, are you sure you only have 1 o-ring in there......I have seen carbs both ways........
Old May 13, 2005 | 02:23 PM
barrister1's Avatar
I'll check that this weekend. I did accidentally drop the new pilot screw on the floor before I put it in, but I thought I had the o-ring and washer back on before I put it in.
Old May 13, 2005 | 02:25 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i would agree with that
sounds like that little idle jet is plugged up (easy to do)
i believe the idle jet on you carb is press fit,,,,,so you will need to yank it out somehow
you will probably see a good bit of crud build up
clean her out,,,,and blow the whole circuit with air
pop her back in and it should be a lot easier to tune that idle,,,using the air/fuel screw
Old May 26, 2005 | 03:36 AM
JonTaylor's Avatar
i was just bouncing around the web and i came across this sight....sweet. I saw this post and had to join because I think I know your answer. I have a 185s and so do a couple of my friends. They all had this problem. The high idle. The problem lies in your carb. Specifically your "slow jet". It is the jet next to the main jet in the carb. Take it out and look at the end of it. there is a slight ridge on the very end that seats in the carb. If it has ever been cranked down to tight or has a ding or whatever then it is not seating correctly. Extra fuel is leaking by the end and feeding extra fuel to your carb at idle. I salvaged another one from an old carb I had. I don't even know if you can get them anymore. But I bet that's your problem. The difference between good and bad is so minor it's hard to tell. Start by just getting a new one if you can. And let me know if this solves it. Good luck!
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
