compression
Old May 15, 2005 | 12:42 PM
H's Avatar
H
Default compression
I've read about lowering your compression by useing 2 base gaskets, but could you increase it by removing the gasket completly and useing a gasket replacement sealant to seal it ? Thanks.
Old May 15, 2005 | 06:12 PM
thebigshow's Avatar
Default compression
yes, by making it thinner or removing it all together in theory, would raise your compression.( if your valves dont smack your piston) but i think your main problem would be getting it seal without a gasket..i use a gasket and a ton of sealant and im having trouble sealing mine..
Old May 15, 2005 | 09:02 PM
eRo's Avatar
eRo
Default compression
by changing the gasket thickness may change your timing some
Old May 15, 2005 | 10:16 PM
H's Avatar
H
Default compression
wouldn't doubling the gasket change the timing as well then?
Old May 15, 2005 | 10:33 PM
eRo's Avatar
eRo
Default compression
yes
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
