lt80 wider
Old May 16, 2005 | 12:14 AM
kendaLt80's Avatar
Default lt80 wider
i just wanted to know what the best way to widening the lt 80 i know of the extened a arms and the nuts that screw on to the studs was just wondering of any other and what has worked for yall thanks
Old May 16, 2005 | 02:13 AM
quadduck's Avatar
Default lt80 wider
The best but most expensive route is true extened a arms and a wider axel for the rear. Most of us just go with a james lucky front ext. kit and spacers for the rear.
Old May 16, 2005 | 02:20 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default lt80 wider
Rims that are wider and/or with a greater offset, and wider tires.
Old May 16, 2005 | 02:24 AM
quadduck's Avatar
Default lt80 wider
Hey recon have you ever ran into that kid again that gave you crap about your signature? I can't remeber his name.
Old May 16, 2005 | 09:30 AM
Red Rider
Default lt80 wider
My signiture???
Old May 16, 2005 | 05:29 PM
Quad4Fun's Avatar
Default lt80 wider
As Quadduck said, the James Lucky front end extenders work well. James Lucky
First decide what you are going to do with the quad. Race, trail ride, both, etc.
Then how wide you want to go. I don't think you need to go real wide if you are just going to do trail riding and stuff with it.
I originally replaced the wheel studs with longer bolts and used 3 nuts to space it out.
This gave about 1" on each side and made a huge difference in the stability.
But we race ours so I then decided to go with the Extenders, I like them so far.
If you only want 1" per side, replacing the studs with bolts is ok. Both in front and Rear
If you want 2 - 2.5", you can get stud extenders or some one piece spacers
If you want 3", then get the JL Extenders in front... or new (expensive) A-Arms (not exactly sure how wide these are??)
There are a few things you can do to the back.
Wider Tires/wheels
Durablue axle
wheel spacers - there are stud extenders and there are one piece spacers available.
You can go with wider tires and wheels. Like 18x9.5x8 Turf Tamers with 8x8 wheels or something.
Which is what I did temporarily to start with..... worked well with the front end extenders.......
But I've decided to go with wheel spacers and smaller tires in the rear.
Will get the Durablue axle when I get the money..
This is just my opinion based on all the reading I've done on this forum, and a little trial and error on my part.
Good Luck [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
QuadRiders
Oct 22, 2015 04:13 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
