Sportsman 700 engine starts screaming
Old May 16, 2005 | 12:10 PM
beaker69's Avatar
Default Sportsman 700 engine starts screaming
I have a 2004 Sportsman 700. When i hit about 30-40 mph the ngine starts screaming but the quad doesn't go any faster. its fine until that point. Any ideas?
Thanks
Old May 16, 2005 | 06:02 PM
spyder6's Avatar
your in low
Old May 16, 2005 | 06:06 PM
beaker69's Avatar
Hilarious.......you should be a comedian!!
Old May 16, 2005 | 06:15 PM
GeorgiaBII's Avatar
belt drive problem. either there is a issue with the spring, weights, or belt. Also it could be the ramps in the secondary.
Old May 16, 2005 | 10:14 PM
DANO38's Avatar
If it won't go any faster than that in high range, I suspect a definate clutch problem. I would check everything out that was already mentioned, but I'll add one more thing. If the white plastic EBS limiter nut loosens up inside of the primary clutch it will not allow the
clutch to fully shift out, therefore limiting the top end. This exact same thing happend to my '03 sp600, and it took my dealer 2 weeks to
figure it out. If you do a search on here you'll see my postings and many others on this same problem.
Old May 17, 2005 | 10:41 AM
beaker69's Avatar
Thanks Dano,
I took off all "the gear" to get to the clutch.....and what do you know.......the white plastic nut was in there rolling around. I think i may have taken out a bushing or bearing also though. But anyway thanks for the help......you nailed it !!!!
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
alix
Jun 28, 2015 03:28 AM
1000gade
May 27, 2015 12:37 PM
