Pilot jet and needle position
Old May 16, 2005 | 10:41 PM
yrrej's Avatar
Default Pilot jet and needle position
ok can some1 tell me where the pilot screw is located on a blaster stock carb and ow do u adjust the needl position thanks
Old May 16, 2005 | 10:58 PM
2fun's Avatar
Do you mean pilot jet, or air screw??
The air screw is on the side of the carb, the pilot jet is inside the carb (you'll have to remove the bowl to get at it).
You have to take the carb top off to get to the needle.
Old May 16, 2005 | 11:09 PM
yrrej's Avatar
the screw is a gold screw on the oposite side of the idle screw on the carb right?????..... yess i no about the needle i just dont know whatt people mean when they said needle position or something?
Old May 17, 2005 | 10:14 PM
yrrej's Avatar
anyone??? please
Old May 17, 2005 | 10:41 PM
RUFFCOUNTRY's Avatar
do you want to adjust needle clip groove position?
Old May 17, 2005 | 11:19 PM
2fun's Avatar
Needle position means which slot the clip is placed on the needle.
If you take out the needle from the carb (make sure you see what slot the clip is on 1st!!), you will see a series of slots in the top of the needle. The 1st slot from the BLUNT end of the needle is the #1 position.
As you move the clip DOWN to the 2nd, 3rd, 4th clip position, etc, you are RICHENING up the midrange which is the RPM range that the needle controls.
So moving the clip DOWN one position is the same as RAISING the needle one position. Regardless of how you phrase it, you are making the carb flow more gas from 1/4 to 3/4 throttle (approximately) .
By DROPPING the needle one clip position (same as RAISING the clip one position), you are LEANING out the midrange.
This make sense??[img]i/expressions/face-icon-small-wink.gif[/img]
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Hw00d
Sep 10, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
