Shifting?
Old May 17, 2005 | 12:21 AM
xXxYFZ450xXx's Avatar
Default Shifting?
Hey guys whats up? Just got my yfz a little wile ago and i was just wondering becouse ive heard that you dont have to use the clutch all the time to shift u just have to let off the gas is this true?... if so is it hard on the clutch or tranny?... thanks alot for your anwsers..
Old May 17, 2005 | 12:25 AM
Six2notScaredofU's Avatar
Default Shifting?
I would ride it awhile before i did that. let it wear in good.just my opinion.
Old May 17, 2005 | 11:14 AM
HoundDog06's Avatar
Default Shifting?
It is never good on the bike to shift without the clutch. Regardless of what some on here will try to tell you, there is no advantage to shifting without the clutch and it wears on the clutch plates and transmissions. Once you get used to the bike, you will be able to clutch-shift as fast as these yahoos can shift without it. Use your clutch for what is was designed for and you will get more life out of your machine.
Happy Riding
~HoundDog
Old May 17, 2005 | 06:47 PM
raptorider660's Avatar
Default Shifting?
u should use the clutch i kno i would especially on a yfz
Old May 17, 2005 | 07:17 PM
Warrior02man's Avatar
Default Shifting?
ok.. dude the last thing u wna do is b hitting from 4th to 5th and breaking ur tranny.. skidding to a hault..a nd go flying over the handlebars.. all because u didn't clutch.. just clutch and don't listen to those ppl that want ur yfz to break.
Old May 17, 2005 | 09:32 PM
86LT250RFatty's Avatar
Default Shifting?
actually most ATV trannies are Constant-Mesh so you dont HAVE to use the clutch, only to get going but its good to do it. if you do do it, just upshift, dont downshift without clutch.
Old May 18, 2005 | 02:14 AM
2fun's Avatar
Default Shifting?
Happy Riding
~HoundDog
I agree.
Shifting CAN be done without using the clutch, but it is a LOT harder on the parts, and you WILL be putting premature wear on them. I ALWAYS use the clutch, even when I am racing someone. A slight (very slight) lead is not worth blowing my tranny over........
Old May 18, 2005 | 04:24 AM
McFly's Avatar
Default Shifting?
not only 01 rapter's loose their trannies.......any bike can. Primary cause, not using the clutch!
Even in a car, once the rev ratio is perfect you can change gear without the clutch. But do you do that in your car? only when the clutch cable is brocken!.....oh yes, dont stop or you will have a problem.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
