Milky Counterbalance oil
Old May 19, 2005 | 07:38 PM
PolarisUK's Avatar
Default Milky Counterbalance oil
What causes this? Is it a leak in the water pump or a leak in the crankshaft seals or something else?
Irrelevant really as the bike I'm doing is having a full rebuild, but I'm just interested!
Old May 19, 2005 | 10:17 PM
stumpjumper400's Avatar
counter balance seal is gone letting in water of antifreeze from the coolant system. full rebuild should take care of it. maybe some others will chime in on some recomendations. it may just need to be changed.
steve
Old May 19, 2005 | 10:40 PM
duneaholic's Avatar
A seal change is in order. I'm not sure on what all is involved but I don't think it's too hard. Good thing you caught it early cause a counterbalancer bearing lockup is not good. Big time rebuild.
Old May 20, 2005 | 06:15 AM
PolarisUK's Avatar
The quad is still currently in use, so we'll be changing the counterbalance oil after every ride to make sure it's always tip-top until I can strip it down. It's a friend's quad and he needs it for working on his farm.
I've devised a quick way of getting the dipstick out of such a fiddly place - just use a piece of rubber tubing slid over the top of it!
I use a funnel with a tube attached to get the oil in there... whole process takes 5 minutes, as I've recommended that he pulls the drain plug every time he puts it away at the end of the day, so it's all out when he comes to it next time. (It's used about once every four days, so it's not a major problem!)
Njrider1230
Jul 29, 2023 05:16 AM
didididididi
May 23, 2004 06:08 PM
radblazer400
Mar 11, 2004 08:30 PM
TINKERMAN
Mar 8, 2004 03:35 AM
mabell1
Jan 30, 2004 02:35 PM
