Milky Green oil out of my Transmission????
Old May 20, 2004 | 10:25 PM
didididididi's Avatar
Default Milky Green oil out of my Transmission????
Yeah. i just changed my transmission fluid on my 85 lt250r. I unscrewed the bolt underneath the motor. The fluid that came out was milky green.(real milky green). I crossed some deep streams, on my last ride(water about too my lower radiator). IM not sure if my radiator fluid is getting into my transmission or it's just the water from the streams. Im pretty sure my radiator fluid is not leaking . Because the fluid in my radiator was recently flushed and checked to be fillled. So ...............get be back guys thanks..
AIM: freeflowww
Rides:85 LT250R
84 ATC 200s
Old May 20, 2004 | 11:27 PM
1987LT250's Avatar
i dont have clue what color streams could make your oil green i woulda thought antifreeze like you. u had your vent tube up under your seat right? thats wierd have you put new oil in and ran it ,then dropped your oil again?
Old May 21, 2004 | 12:14 AM
KFXCarnage's Avatar
I know on alot of my dirt bikes I have owned when they had milky white oil draned from them the little seal behind the radiator pump fan was leaking and a new seal fixed it.I had mine mixed half and half though.Duno if it would be green if it was straight antifreeze in your radiator though.
Maybe you sucked up some swamp juice hehe...
Old May 23, 2004 | 06:08 PM
Billqdracer's Avatar
just condensation will make your oil do this, does it sit in a sweaty garage? if it persists to turning whitish green again fix it because you will wreck it with lack of lube.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Whitelx1
Oct 2, 2015 10:55 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
