SP Problems...
Old May 19, 2005 | 07:40 PM
maddog56's Avatar
Default SP Problems...
My 2000 SP 500 has a problem, the electronics dont work. Brand new battery #2, and still nothing. Even when the bike is running, nothing works. Now I know everything is hooked up correctly and I havent come acrossed any shorts in the system, so what is wrong? I've heard it may be a bad rectifier? Or voltage regulator, which I thought was the same thing. Can anyone help?
Old May 19, 2005 | 08:01 PM
carpenter's Avatar
SOUNDS LIKE THE VOLTAGE REGULATOR. I HAD THE SAME KIND OF PROBLEMS WITH MY. AND THE REGULATOR HAD TWO WIRES UNPLUGED.
Old May 20, 2005 | 07:24 PM
maddog56's Avatar
Does voltage regulator = rectifier???
Old May 21, 2005 | 03:04 AM
Polaris500HO4x4's Avatar
not quite the same thing... a voltage regulator regulates how many volts go into the appliance thus its name
a rectifier is like a one way valve almost lets voltage go only one way
Old May 22, 2005 | 05:09 PM
maddog56's Avatar
Ok, so what am I looking to replace? What/where is the voltage regulator?
Old May 23, 2005 | 01:30 AM
see if u can run a volt meter across the wires that come out of the voltage regulator and see what it reads
Sumdumgi
Nov 27, 2014 10:15 PM
mt_wi86
May 16, 2013 04:19 PM
cstrait37
Oct 28, 2012 04:13 PM
88trx250x
Aug 9, 2011 06:30 AM
