Override Buton Failure...
Old May 22, 2005 | 07:29 AM
PolarisUK's Avatar
Default Override Buton Failure...
My 400L doesn't have any rev limit when in reverse... it's OK most of the time, just remember to take it easy, but it can be dangerous when I'm pulling things around.
Anyone know any likely reasons for this?
Old May 22, 2005 | 09:48 AM
ftwflh's Avatar
I would say someone unhooked it.Check the wire block and see if there is a black wire unplugged.I bet the limiter went bad and they just bypassed it.
Old May 22, 2005 | 09:59 AM
SPORTSMAN70003's Avatar
Alot of people unhook them I have mine overridden.
Old May 22, 2005 | 11:48 AM
kentuck's Avatar
what is the reason for over rideing the switch?
Old May 22, 2005 | 12:00 PM
Lazyness lol It makes it easier for someone who plows or muds alot that way when your in 4x4 you don't have to push the button while in reverse and you have 4x4 and full power in reverse.
Old May 22, 2005 | 01:06 PM
ftwflh's Avatar
THe older modles had a habit of going bad and it is cheaper to bypass them.Plus when you clutch one real high reverse will not even hit without useing the button and it gets anoying.
Old May 23, 2005 | 05:49 AM
PolarisUK's Avatar
The 4X4 doesn't work in reverse, so I think it's something a little more complex...
andyems
May 8, 2002 10:41 PM
andyems
Jan 23, 2002 08:02 PM
lyle1
Mar 3, 2001 12:44 PM
JeremyB
Jan 19, 2000 12:08 AM
