Blaster stator wiring
Old May 21, 2005 | 01:36 AM
sinagoga's Avatar
Default Blaster stator wiring
Does anyone know which wires to use at the stator to test the stator lighting and power coil? The wires are a different color than my banshee. Thanks
Old May 21, 2005 | 01:52 AM
hondabuster's Avatar
The lighting coil is the yellow/red, and black. it should read .16 to .24 ohms.
The pick up coil is the white/red, and black, and should read 16 to 24 ohms
The source coil, black/red, to black, should be 192 to 288 ohms
Old Nov 23, 2019 | 01:52 PM
Mike Green's Avatar
Default Black/red wire not registering on my 2001 yamaha blaster with ohm tester.what does th
My red and black wire on my stator to my 2001 Yamaha Blaster is not registering on a ohm meter I don't know what it does but I have not been able to get Spark can anyone help please?
Old Nov 24, 2019 | 04:14 AM
According to the post above, if you put an ohm meter between black, and red/black wires, you should get 192 to 288 ohms. If you get open circuit, your source coil has had it. You may be able to buy them separate to the stator. Strangely, the parts books don't list a "source coil" at all on the Banshee, just lighting, charging and pulse coils.
kj4ltc
25
Dec 3, 2017 07:29 PM
cwilson1972
Jan 23, 2014 10:41 AM
jcote
ATC 3-Wheelers
Aug 8, 2008 11:03 PM
kdrifter440
Dec 8, 2004 09:52 AM
