Override Buton Failure...
My 400L doesn't have any rev limit when in reverse... it's OK most of the time, just remember to take it easy, but it can be dangerous when I'm pulling things around.
Anyone know any likely reasons for this?
I would say someone unhooked it.Check the wire block and see if there is a black wire unplugged.I bet the limiter went bad and they just bypassed it.
THe older modles had a habit of going bad and it is cheaper to bypass them.Plus when you clutch one real high reverse will not even hit without useing the button and it gets anoying.
