help bad badger
Old May 22, 2005 | 10:33 PM
trxdad's Avatar
Default help bad badger
does anyone know if the raptor 80 motor will fit the 2000 yamaha badger and how much the motor is if it will work thanks
Old May 22, 2005 | 10:58 PM
UltimateAussie's Avatar
i doubt they are different, the engine in the badger was bullet proof i doubt they changed it. but im not sure
Old May 23, 2005 | 10:46 AM
asfasasu3's Avatar
The motors are the same. The older Badger, moto 4's were 4 speeds. But other than that, they are the same. another thing is the champ's motor is also the same except for being a 4 speed and having a larger bore. (by the way, you can put the 4th gear into a newer tranny and also put the bigger bore top end on a newer motor) You can make one of these fly by using the bigger bore and 4 spped swap, BUT, the suspension will really hold you back. (altough they make great flat trackers!!)
Good luck!!!
armyman
Nov 2, 2012 05:19 PM
skeeterbug
Jan 24, 2005 05:24 PM
jrime
Dec 23, 2004 01:48 AM
RippinBlaster
Jun 22, 2004 08:39 AM
