rubicon - warn 424 select help
Old May 23, 2005 | 06:14 PM
rubired04's Avatar
Default rubicon - warn 424 select help
I installed a warn 424 kit on my 2004 rubicon. How important is it to have the ANTI- ROTATION STRAP installed so that there is no rotation in the unit? I could not find a location on my frame to connect the strap to that would not allow the unit to rotate at all in either direction. Is this strap used to keep the unit completely tight from rotating at all or to just keep the unit from doing a full rotation? Any help is appreciated.[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 23, 2005 | 06:56 PM
LittleBill's Avatar
i'll say it once, install the strap, nothing will stop the unit from spinning around and destroying the cabling, INSTALL it the directions will tell you where
Old May 23, 2005 | 08:19 PM
sandpit's Avatar
It's there for a reason.
Old May 23, 2005 | 09:10 PM
RancherS01's Avatar
I just noticed on my Rancher that the strap has broken off, not sure how long ago that happened, but I'll have to rig something else up. I agree with the above, if they say to install it, there must be a reason.
Old May 24, 2005 | 12:44 AM
RedGoblin's Avatar
Install it. It does not matter if there is some "play" in the unit. The main objective is to keep it from spinning around completely, taking the cable with it and potentially messing up some internal and external parts VERY BADLY.
Old May 24, 2005 | 12:35 PM
action450s's Avatar
WHat this guy said!!!
Jeff Roper
Feb 1, 2022 11:48 AM
panicmanic
Sep 28, 2015 12:59 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
