wiring qusetion
Old May 26, 2005 | 12:58 PM
devocorky's Avatar
Default wiring qusetion
I had a few topics about this already but i have run into another potential problem. I installed a cheap winch that has only two wires running from the remote/switch deal ( red and black ) that i hooked up directly to the battery. Ever since that my battery is being drained to the point when it sits for a while i cant start it. I charged op the battery and unhoked the two wires to the battery from the winch and now it seems fine. Why would this be?? I even installed a heavy duty toggle inline to stop the power to the remote switch. I dunno???[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 26, 2005 | 01:00 PM
devocorky's Avatar
....sorry, i dont know why this posted twice..
Old May 27, 2005 | 04:18 PM
devocorky's Avatar
I wonder if i should ground it to something else rather than the battery??
Old May 27, 2005 | 04:45 PM
quicksilver's Avatar
i'm pretty good at electrical stuff, that's what i do at the Ford dealership that i work at.
grounding it at somewhere other than the battery probably wont help, and i would personally recommend trying to keep the ground at the battery. This is the strongest ground you can possibly have, and gives you the most efficient winch operation.
Without actually seeing how your winch is set up, It's impossible to diagnose your problem. I guess make sure your connections are tight and that you wired everything up correctly, perhaps you hooked something up wrong and a relay is staying turned on.
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
