Moving Shifter?
Old May 29, 2005 | 01:39 AM
Ricke's Avatar
Default Moving Shifter?
i just got new boots, but i cant get my foot under the shifter. on the raptor how do you adjust it?
Old May 29, 2005 | 03:03 AM
UltimateAussie's Avatar
there should be a little bolt at the beggining of the shift lever that holds the shifter to the shaft. lossen the bolt and the shifter should slide of the splines its on. pull it off a little and then move it up or down to your liking then aligne the splines as best you can and slip the lever on there, it may take some wiggleing and stuff but then you so if you like it and if you do you tighten up that bolt
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Dewhound
Apr 20, 2017 02:25 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
