Gearing for TRX 450R
Old Jun 1, 2005 | 01:42 AM
Quadracers's Avatar
Default Gearing ?
I have a built TRX 450R Honda. What gearing should I run with 22 haulers for 300 ft. drags?
Old Jun 1, 2005 | 04:12 AM
White7's Avatar
Default Gearing for TRX 450R
stock is a 14/38 i run a 14/39 It gives a little better punch off the line and you only lose about 2mph on the top end,,stay away from the 13 front its to low
Old Jun 1, 2005 | 11:39 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
I don't think the 13 is too low. For trails I run a 13/38, for dunes I run a 13/37
I have even used the 13/37 setup on the trails and it works verywell.
Old Jun 1, 2005 | 05:14 PM
White7's Avatar
Ya i just think a 13 is to much of a sacrifice on the top end
a little info for the first guy
STOCK
Front: 14 Tooth
Rear: 38 Tooth
Calculated Max speed: 80 MPH
A BIT MORE BOTTOM END
Front: 14 Tooth
Rear: 39 Tooth
Calculated Max Speed: 77-78 MPH
A BIT MORE BOTTON END YET
Front: 13 Tooth
Rear: 38 Tooth
Calculated Max Speed: 74-76 MPH
MAX BOTTOM END
Front: 13 Tooth
Rear: 39 Tooth
Calculated Max Speed: 72-73 MPH
Old Jun 1, 2005 | 08:04 PM
Quadracers's Avatar
well im running a 13/38 do you think that is too low?
Old Jun 1, 2005 | 08:42 PM
Quadracers's Avatar
This is my dilemma. My trx was built by Sparks. It has the JE 13.8:1 94mm piston, X4 hi rev cam, porting, titanium valves, 41mm FCR carb, new dyna-tech ignition and the X6 exhuast. I've got 22x11x8 7 paddle skat trak haulers and with 14x38 (stock) gearing it will bog if I try to start in 2nd. With 13x38 gearing I have no problem doing 2nd gear starts but I'm losing some top speed to the YFZ about 1 bike length in 300ft. Both of my brothers have YFZ that were also built by Sparks with the identical equipment that I have except they were bored over 1mm to make them true 450's. All 3 quads make about 52 hp. If I run 14x38 I will have to do 1st gear starts which may not be too bad since the Honda's 1st gear is taller than the YFZ. With 14x38 the quad will barely make it to 4th in 300ft. With 13x38 the quad is screaming in 4th in 300ft. Im thinking that going lower would allow for 2nd gear starts and get me into 5th for a little quicker acceleration and overall topspeed. Like 13x40. Any Suggestions now that you have all the info would be appreciated?
Old Jun 1, 2005 | 09:30 PM
Pirate Biker
Limping Rider!
Try 13/37
For every tooth you go down in front its about equal to going up three in back. So go down one in front and down one in back.
I raced a friend of mine, also on a 450r, on the beach in Oregon. Top speed I was about 1 mph faster. I had the 13/37 with 20" hauler paddles. He had 14/38 with 22" hauler paddles. With the 13/37 I'm quicker than all Raptors I've raced but they have a faster top end, although they can't catch me until we're both in 5th.
Old Jun 1, 2005 | 11:21 PM
TractorPacker's Avatar
Do you have a balloon?
Originally posted by: Red400EXRod
Try 13/37
[img]i/expressions/face-icon-small-blush.gif[/img]
I would think try 14 and 39, if you have one laying around.
Old Jun 2, 2005 | 12:00 AM
Pirate Biker
Limping Rider!
You probably want your 37 back, don't you TP?
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
