best way through deep mud
Old Oct 9, 2000 | 03:02 PM
hillclimbing4kix's Avatar
ok we have a 4-wheel party comming up the end of the month trucks jeeps 4-wheelers and i just wanted to know you opinion on the best way to get through the deep stuff i have been stuck 1 time to many burried it up to the seat this past weekend took about an hour getting it out had a good time though so do i fly through it and roost every body or creep and get stuck
Old Oct 9, 2000 | 03:16 PM
FearNothing's Avatar
Just put it in low range, and keep it floored. Momentum is everything. Make sure it keeps moving.
Old Oct 9, 2000 | 03:30 PM
Thor's Avatar
Don't enter the water too fast. You may drown your belt with the splashing and spray. Like he said Just put it in low range, and keep it floored. Momentum is everything. Make sure it keeps moving. Sometimes a little left to right Body English on the handlebars can make the difference in a wheel finding traction. But keep moving.
If the first guy makes it through the hole, the chances are good that you will too. But... don't be the last guy to venture in. Chances are that the whole thing will be all rutted and churned up decreasing your chances.
From time to time I have noticed that the best route is through the middle, because so many people try and go around the edges.
Stay away from the cat tails. That muck is usually bottomless.
Mudmachines would work well on the back of this quad.
Old Oct 9, 2000 | 04:26 PM
JOEMAG500's Avatar
A trail boss is a two wheel drive with only one gear range. A good addition would be some more agressive tires. Bearclaws or something similar would make a huge difference. Momentum is everything with a two wheel drive so putting along is not the best idea.
Customer Service #1
May 15, 2020 08:46 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
switzomatic
Aug 24, 2015 12:57 PM
