Clutch will not work 250R
Old Jun 14, 2005 | 10:42 AM
Bigmo's Avatar
Default Clutch will not work
I have put in a new clutch and I still can't get the gears to disengage. I pull the clutch lever in and Sprocket will rotate freely. I have adjusted the clutch cable with no luck.
Questions:
Does the case have to be sealed for the clutch to work properley?
What else should I be looking at?
Thank you for any help you can give.
Old Jun 14, 2005 | 10:34 PM
atc250ratic's Avatar
Default Clutch will not work 250R
Is it a new basket. I have had a situation where new plates were getting caught in the tiny grooves in a slightly worn basket ?
Cant wait to see some pictures. The clutch isn't disengaging right ? Thats the problem your having right or do I need some reading lessons ?
Old Jun 15, 2005 | 10:27 AM
Bigmo's Avatar
Well I got it fixed last night. I guess the case has to be sealed for the clutch to work properly. I did look at the clutch basket and it looked and felt okay. However, now I have another problem the water pump leaks anti freeze and I know it is the seal but I think I messed up the metal flange that goes around the shaft. I am going back to Honda tonight to see how I can fix that. the positive note is that I got it started for the 1st time in the two years I have had. It has been a long and expensive road to restore the beast.
Old Jun 26, 2005 | 01:01 AM
Very cool !
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
coolguy420
Jul 10, 2015 01:17 AM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
