E in shift window
Old Jun 14, 2005 | 09:18 PM
Kerbbirds's Avatar
Default E in shift window
My 03 700 quit showing the gears in the selector window in the speedometer, shows low and nuetral but just shows E in the rest, any Ideas.:[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 15, 2005 | 01:20 AM
luckycharms5's Avatar
Mine did the same thing. First it showed a E in reverse only. Then it went away and showed N in reverse. Its not your linkage so dont mess. take the 2 switches off the transmission and inspect for dirt and bad connections. If they look good and your still getting a E then replace the switch. Its around 60.00 sorry I cant remember what switch it was Iam in the house now but I think it was the rear. the switch is like a toggol switch and its a sign that its not making a clean click. Good luck
Old Jun 15, 2005 | 01:22 AM
Oh ya I forgot to mention. Check your 4x4 in reverse override. It might not let you have 4x4 in reverse. thats a sure sign it the switch.
Old Jun 15, 2005 | 04:03 AM
jimmypsp700's Avatar
Thats an error code, check your manual, the linkage could be off and in between gears.
Jim
Old Jun 16, 2005 | 10:22 AM
ZMan079's Avatar
luckycharms5,
You may have a short or something grounding somewhere. Not sure if you have any mods or not, but I had a very similar problem. My Reverse light (which I mounted to the plastic rack) mount had worked a little loose and was touch the metal frame that runs around the rear side of the rear plastic rack (Mind you I tested all of my wires and pulled my hair out before discovering this). It basically completed the ground and the light would stay on all of the time. It also completed a ground back to the Purple wire in the Pod , and it would send an E to the Speedo except when I was in Reverse. I did get ovverride in reverse with the yellow button and my RO Ovverride switch, but I would not see the AWD light on in any of the forward gears. I did not do a test up on the jacks, but just from riding it felt like I never engaged AWD. I put a rubber spacer and all is well now.....
Here is a link to my post about my problem:
E on Pod/Electrical Problems
Hope this helps,
ZMan079
Old Jun 16, 2005 | 12:21 PM
RallyRider05's Avatar
anyone know y my sp 400 only says 101 all the time where the rpm is. also i was shifting in and out of reverse to low and in the prosses there was no r or l or anything just blank?
also another time i was getting to drive it and it jumped of the line realy quick like the brake was on or something but it wasnt? it also felt weaker from the last time i drove it?
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
