TTR125 leaking gas problem. Need help!
Old Jun 17, 2005 | 12:07 AM
Jeff00000168's Avatar
Default TTR125 leaking gas problem. Need help!
I have a TTR125 that's leaking gas from the over flow hose. Gas stops leaking when I switch the fuel **** off. Regardless with the engine running or not, gas still leaks with the fuel **** on.
Thanks in advance!
Old Jun 17, 2005 | 02:33 AM
lusty's Avatar
Just guessing here. Is the float stuck? BL
Old Jun 17, 2005 | 03:28 AM
Thanks for the reply Barry! Gonna check it out in a bit. I'm too lazy to open the carburetor. LOL!
Old Jun 17, 2005 | 03:32 AM
Jibrille's Avatar
I'd definately check the float.
Old Jun 17, 2005 | 04:50 AM
superarbeau's Avatar
I dont know if it would be the same but my kodiak did the same thing the first weekend i had it, I moved the screw that drains the bowl of the carb out and in again and took it for a ride and it has'nt leaked since.
Old Jun 17, 2005 | 05:22 AM
Yeah, did unscrew/screw the drain screw but still the same. Still leakin'. Still have to check the carburetor. Too lazy to open it up and it's gettin' late. I'll do it in the morning. Thanks guys for the reply! I'll post an update tomorrow.
Old Jun 17, 2005 | 10:37 AM
UltimateAussie's Avatar
yeah its the float. my three wheeler did that. and they dont leak when your riding so i wouldnt worry about it. just make sure yuou turn off the gas when you park
exmotocrosser
Sep 13, 2019 06:12 AM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
