tire size help.
Old Jun 17, 2005 | 08:07 PM
ridinsmooth's Avatar
Default tire size help.
i want to get some new tire for my 250ex but the back tire size is 22x10X9 i think well most tires say 22x11x9 so will a tire that size fit on my stock rims and can you tell me which number means what.
Old Jun 19, 2005 | 12:52 AM
come on yall cant tell me a simple question like that.
Old Jun 19, 2005 | 09:24 PM
Wheelerbob's Avatar
Yes they will fit, they will be 1 inch wider that's all, the 22= tire diameter, 11= tire width, 9= rim diameter. But if i were you i'd go with a 20/11/9, I put 20/11/9 razor's on mine and it made a good improvement in acceleration and stability. Hope this help's
Old Jun 20, 2005 | 12:29 AM
how is that supposed to fit on the rim when it is 1 inch wider than the rim.
Old Nov 13, 2005 | 03:27 AM
tnewguy's Avatar
it will fit, i just changed the stock 25-8-12 and 25-11-12 with 27-10-12 and 27-12-12. Thats 2 inches wider in the front alone, on the same rims
Old Nov 20, 2005 | 03:27 PM
tyler711's Avatar
THe tread is 1 inch wider. THink of the wheel and tire - if you look at it from behind, the wheel is always thinner than the tread, the difference is made up for as the sidewall curves in. A wider tire will be slightly shorter than the same height tire with a thinner tread because more sidewall is used curving inwards to the rim,
Bratman2
Aug 6, 2022 01:42 AM
Schneider
Jul 24, 2015 05:05 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
