Do I need to prime the oil pump?
Old Jun 18, 2005 | 12:35 PM
NHarrison2's Avatar
Default Do I need to prime the oil pump?
I'll be changing my 05 sportsman 500 ho oil for the 1st time. Do I need to prime the pump? I didn't on my 04.5. I just need to drain the oil holder and the crank case. Right? Thanks for the help.
Noble
Old Jun 18, 2005 | 05:47 PM
NHarrison2's Avatar
Anybody? Thanks.
Noble
Old Jun 18, 2005 | 07:58 PM
spyder6's Avatar
nope. and theres no drainplug to my understanding on the crank case, you just drain the resivoir
Old Jun 18, 2005 | 11:04 PM
crasher22's Avatar
For the first oil change I would remove the screen located in the lower oil delivery hose and remove the screen fitting (3) from
the oil tank. Clean and reinstall the fitting,Reattach the oil line. torquing to 25 ft. lbs. This screen will catch any metal filings that may be in the oil.
When I did the one on my 500 there was nothing in the screen but I wanted to be safe anyways.
NOTE: The fitting threadsmust be sealed with Loctitet PST 505 or PTFE seal tape. The fitting must also line up with the mark (4) on the
rear side of the oil tank.
After this you will have to prime the oil pump
Old Jun 19, 2005 | 12:02 AM
NHarrison2's Avatar
Thanks
Old Jun 19, 2005 | 12:23 AM
spyder6's Avatar
thats what the oil filter is for
Old Jun 19, 2005 | 01:30 AM
mudmaster250's Avatar
its a prefilter to catch big stuff
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
