warrior sprocket q
the stock sprokes on a warrior 93 are a 13 and a 40 right would a 15 in front and a 44 average out as the same or not all rockey mtn has for front is a 12 and 15 and they only have 41 and up in back so wat would average out to about the same also would a 12 in front and 41 in back sacrifice top speed much also im not sure wats on there now but ive had it at 75 so far with my gps its pretyty modified
if u go bigger with the rear that makes for better top speed and if u drop 1 in the front its equivlant to dropping 3 teeth in the rear so if u run a 12-41 gearing u would loose about 2-3 mph cause i lost about 5mph wirh running a 12-40
Remember also this all adds up to more shifting. I tried short gearing but it just felt like it made first useless and I started at 2nd with a 5 speed gearbox. More power or less you weigh the higher the gears you want, less power or the more you weigh you want lower gears.
