warrior sprocket q
Old Jun 21, 2005 | 10:10 PM
speedped79's Avatar
Default warrior sprocket q
the stock sprokes on a warrior 93 are a 13 and a 40 right would a 15 in front and a 44 average out as the same or not all rockey mtn has for front is a 12 and 15 and they only have 41 and up in back so wat would average out to about the same also would a 12 in front and 41 in back sacrifice top speed much also im not sure wats on there now but ive had it at 75 so far with my gps its pretyty modified
Old Jun 21, 2005 | 10:13 PM
yamaharaptor350's Avatar
if u run a 12 front and 41 in the back u will lose about 2mph on top speed. I have a 12-40 gearing on mine and i lost about 4-5mph on top speed but the bottom end is much better.
Old Jun 21, 2005 | 10:16 PM
speedped79's Avatar
that dosnt seem to make sence how would i lose 2 wen u lost 5 im also adding bigger to the rear which adds accel and losed topspeed
Old Jun 21, 2005 | 11:20 PM
if u go bigger with the rear that makes for better top speed and if u drop 1 in the front its equivlant to dropping 3 teeth in the rear so if u run a 12-41 gearing u would loose about 2-3 mph cause i lost about 5mph wirh running a 12-40
Old Jun 21, 2005 | 11:28 PM
speedped79's Avatar
http://www.ronnies.com/store/atvchainfaq.html can i say owned lol
Old Jun 21, 2005 | 11:30 PM
speedped79's Avatar
When selecting sprockets other than stock: for more LOW END, go larger on the rear, or lower on the front. For more TOP END, go lower on the rear, or larger on the front.
Old Jun 22, 2005 | 02:38 AM
JakalWarrior's Avatar
Remember also this all adds up to more shifting. I tried short gearing but it just felt like it made first useless and I started at 2nd with a 5 speed gearbox. More power or less you weigh the higher the gears you want, less power or the more you weigh you want lower gears.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
