250R chain adjustment
Old Oct 11, 2000 | 04:57 PM
Snapper_Rider's Avatar
Whats the procedure for adjusting the chain on an 86 250R? How much slack shoub be in the chain? Thanks
Old Oct 11, 2000 | 05:41 PM
87_250R's Avatar
You loosen the 2 bolts on the back of the swing-arm. On the left side (just before the sprocket) there is a thing that has a couple holes in it (it is kind of hard to tell you in writing) down is tighten, up is loosen (I think). The slack in the center of the chain should be 30-40mm (1.2-1.6 inch) if you have any questions feel free to ask.
Old Oct 11, 2000 | 05:44 PM
retro's Avatar
Loosen up the allen screws with a 6mm allen wrench, stick something in the carrier grooves and rotate it forward or backwards untill you have about 1 1/2" play in the chain. It is easier to have someone sit on the seat while you adjust it.
ERIC
Old Oct 11, 2000 | 11:22 PM
87_250R's Avatar
retro is simpler to under stand. sorry
Firefighter400
Oct 8, 2022 06:38 PM
frostphase
Aug 23, 2015 07:36 PM
goosemasterkl
Aug 23, 2015 11:36 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
CRamshaw777
Jul 18, 2015 05:46 PM
