A New Electrical Gremlin
Old Jun 24, 2005 | 10:11 PM
Folger's Avatar
Default A New Electrical Gremlin
Well, at least new for me. I rode my wheeler yesterday, and everything was fine. It's an '02 Sportsman 400, by the way. Anyways today it couldn't start it with the key. So I pull started it. Ran fine and all, but the speedo and odomertor didn't come on. The taillight and headlights work when it's running. I replaced all the circut breakers with fuses a couple years ago, and they where all good. Then I pull started it again, the fan ran, everything lit up, speedo, odometer and all, then it all quit again. I'm not sure what to think. I put a charger on the battery for a while. Well my winch works fine, but still the same old story with everything else. Anyone have any ideas? Thanks for any info.
Old Jun 24, 2005 | 10:16 PM
2manytoys's Avatar
When you say it wouldnt start do you mean it would not turn over or it would turn but not fire.
Old Jun 24, 2005 | 11:18 PM
Folger's Avatar
It won't turn over. It's like the battery is dead, except my winch still works. So I don't know what the hell to think.
Old Jun 25, 2005 | 03:57 PM
Folger's Avatar
TTT.
Old Jun 25, 2005 | 05:13 PM
powerslider's Avatar
Might it be the ignition switch???
Old Jun 26, 2005 | 12:00 PM
bigdumbfun's Avatar
I had a very similar problem with my scrambler. I could pull start it but not use the key. I don't have any acessories but the headlight wouldn't work when I pull started it either. Then I noticed one night, that the light would come on if I turned to the right and go off if I turned to the left. Long story short after tearing into all of the wiring under the nose piece I traced it up to the kill switch. the wiring plugsinto the box with a locking clip. The clip wasn't locked in so it could unplug itself. Almost a month of head scratching and about an hour with a volt meter came down to pushing in a clip on the handlebars.
I hope you are so lucky.
Old Jun 28, 2005 | 03:38 PM
Folger's Avatar
Figured it out Saturday. I had a broken wire coming off the starter solinoid. Hard to believe that one little wire could be such a problem, but easy fix. Glad it was nothing major. Thanks for all the feedback.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
