Rebulding top end on sons lt 80 need to know cc's
Old Jun 25, 2005 | 06:33 AM
quadduck's Avatar
Default Rebulding top end on sons lt 80 need to know cc's
I was just curious how you would figure out the cc's on my sons 80 after the bigger piston was installed, its a wiseco(sorry jack) 2028cd-51.50 mm. It is still the stock crank and rod. Also whats the best way to break the motor in without siezing up the piston?
Old Jun 25, 2005 | 10:02 AM
hateful's Avatar
the best way is to use the oem pistons theyneed no break in and we have never had a problem.
Old Jun 25, 2005 | 02:46 PM
quadduck's Avatar
Yeah I heard that but I was told by the guy at the shop that I had to go with a wiseco because it is too large for a factory piston[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 25, 2005 | 06:22 PM
hateful's Avatar
factory pistons come in 50.50 and 51.00 so not sure why he told you that
Old Jun 25, 2005 | 09:38 PM
quadduck's Avatar
Mine is a 51.50, maybe thats why.
Old Jun 26, 2005 | 10:55 AM
LT80's Avatar
LT80 Expert
Yes the 51.5 has to be a Weisco. Stock to 51mm.
If it's still apart, take coarse sandpaper and rough up below the ring gaps. That should help.Don't be afraid, get agressive.
51.5 x 51.5 x .7854 x 42=87.489cc's.
Hot and cold it a few times. Then just don't sustain a high rpm for a lil while.
Anyone else getting an error? I replied to this yesterday and got an error page. Apparently it didn't post.
Old Jun 26, 2005 | 11:20 AM
emeraldisleatv's Avatar
Did ye guys not do maths in school, use the cylinder volume formula.
Old Jun 26, 2005 | 04:19 PM
quadduck's Avatar
Thanks Jack, yes I have been getting the errors for the last 3 days off and on. As for sanding its too late, I already went ahead and installed the head yesterday and ran into the float or something sticking on the carb, and it filled up the crank case I think. So I Took off the carb(20mm) and the needle doesn't seem to be seating. Boy those 20 mm carbs are a pain to take off and put on, not much clearance.
Emeraldiselatv if I knew how to figure out the cc's I would not have asked, BUT THANKS FOR YOUR OPINION AS I'LL BE SURE TO ROUND FILE IT!
Why respond if you have nothing to offer? this is a kids quad forum where parents can ask experts like jack what to do.
Old Jun 27, 2005 | 03:49 PM
Originally posted by: quadduck
Thanks Jack, yes I have been getting the errors for the last 3 days off and on. As for sanding its too late, I already went ahead and installed the head yesterday and ran into the float or something sticking on the carb, and it filled up the crank case I think. So I Took off the carb(20mm) and the needle doesn't seem to be seating. Boy those 20 mm carbs are a pain to take off and put on, not much clearance.Emeraldiselatv if I knew how to figure out the cc's I would not have asked, BUT THANKS FOR YOUR OPINION AS I'LL BE SURE TO ROUND FILE IT!Why respond if you have nothing to offer? this is a kids quad forum where parents can ask experts like jack what to do.
JEES sorry, just sayin, sorry if I've go nothing to offer.
Whitelx1
Oct 2, 2015 10:55 PM
2many2ride
Sep 27, 2015 04:35 AM
kampswas
Sep 23, 2015 05:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
