400ex PROBLEMS
Old Oct 12, 2000 | 12:00 PM
theEXorcist's Avatar
It is backfiring when it hits the rev limiter in the air (i have to pull the rear end down quick to land, so i smash the throttle). Also it is missfiring alot. I need to know what causes backfiring and misfiring.
A while ago when i removed my headpipes to install my 3 quart pingry, i never replaced the copper crush gaskets, could this be the problem?
plz help
Old Oct 12, 2000 | 12:06 PM
tbass2's Avatar
the gaskets are not the problem. I don't know but I would start with the simple stuff first. Maybe a new spark plug, jetting, or try to see if anything is blocking the exaust flow.
Old Oct 12, 2000 | 12:09 PM
What i meant by the gaskets was that maybe a leak there caused a hole to wear in the piston, causing backfires and misfires
Old Oct 12, 2000 | 12:25 PM
garyc660R's Avatar
Did you develop the misfiring problem only after having the exhaust off and back on? Has this ever occured before?
Old Oct 12, 2000 | 08:20 PM
CG400exMaster's Avatar
yeah, it misfires ever since i took the headpipes off... i had to take them off again to align up the white bros slip on too...
Old Oct 14, 2000 | 03:10 PM
400exalltheway's Avatar
jet a little lower maybe i had the same problem w/ my wb pipe. i thought i was jetted to lean and the backfiring only got worse so i jetted a little leaner and ran fine
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
