Green Spring Installation???
Old Oct 13, 2000 | 10:16 AM
325boss's Avatar
Ok, guys, i'm back again. I got my Green Spring from RcR and was wondering how to install it. I think i have a good idea how but just post and tell me so that i don't do somethig wrong. Thanx.
Old Oct 13, 2000 | 10:28 AM
DieselPro's Avatar
Pull the clutch cover, and swap 'em. Just keep the X cast in the cover aligned with the X in the spider.
Old Oct 13, 2000 | 02:45 PM
toyman's Avatar
I scratched a line in the plate vs. clutch to keep alignment. Loosen center bolt (stick screwdriver thru clutch to floorboard) then remove 6 outer bolts and center. Install new spring.. torque center to 40 ftlbs 6 outer to 15ftlbs. re-install cover and pop wheelies...
Old Oct 13, 2000 | 08:19 PM
Polarx250's Avatar
I agree with toyman on the 15lb of torque on the 6 outer bolts because if your wrench is off a pound or two they Will Wring off
shimanok2
Jan 29, 2016 07:37 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
rawbdiggity
Sep 7, 2015 12:05 PM
toonces
Sep 5, 2015 01:14 PM
