Steering issues ?
Old Jul 5, 2005 | 06:02 PM
VT1911's Avatar
Default Steering issues ?
I've been shopping for a new ATV (600 class) and have read some tests and they have mentioned jerky steering at higher speeds and when hitting rocks etc. on the AC. Does anyone know if this is a problem on the 2005+ models or could it just be a byproduct of the longer travel suspension? The tests I have read didn't have an answer for it. Is it really that bad?
Old Jul 5, 2005 | 07:23 PM
Bear4570's Avatar
It's a problem with any 5 psi tire at high speed, not just AC. Why do people think that an off road vehicle made for trail riding, rough country, rock crawling, etc will run as fast as a car down the freeway without some adverse conditions jumping out to bite them.
Old Jul 5, 2005 | 11:42 PM
weez440's Avatar
i have driven everything out there and i have never noticed any problems with the steering on the cat. but then again people need things to complain about. i dunno if they think they are harder steering then the others or people just need to build up a lil arm strength but it isn't that bad.
Old Jul 6, 2005 | 09:46 AM
VT1911's Avatar
Thanks guy's,
I found another article on an older model(?) and they mentioned that the steering geometry was designed to lighten the steering at slow speeds but tended to make it more jittery at higher speeds. I guess that would do it. I'm really not concerned since I will be mostly cruising slow but I also didn't want it to be a slower speed problem either.
Old Jul 6, 2005 | 02:28 PM
Chumley's Avatar
My 05 650v2 handles rock solid at high speed, gravel or paved. My buddies Grizz freaks me out a little at high speeds, that thing is all over the place.
Old Jul 12, 2005 | 10:21 PM
LittleBill's Avatar
you can completely change the characteristics of that simply by changin the toe in or out, depending on what u want,
Sportsman850
Jul 31, 2015 04:25 PM
Gtsordo
Jul 22, 2015 01:27 PM
mdrkcckv
Jul 22, 2015 09:10 AM
1966F100
Jul 12, 2015 03:01 AM
Scottma518
Jul 10, 2015 12:42 AM
