Gas shut off on kfx 400
i was just wandering if there is any way to shut off the gas.
On my 05 there is just on, res, and pri and all those settings let gas flow and it makes it really hard to change jetting.
Like Hugh said, it's vacuum operated. So the gas should not flow when it's in the pri or res setting. If it does flow fuel on these settings w/ the engine off then you probably need to rebuild your petcock.
PRI is for diagnostic purposes only, you should not be running your machine in that setting at all. I'm sure it says that in the owners manual.
It just stays ON all the time.
Originally posted by: yamahawarriormods
thats not true i wanted to drain my gas the other day the only way it would drain is on pri that did it and it didnt have to be running
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
