05 Trail Boss problem
Old Jul 10, 2005 | 02:11 AM
Jason8225's Avatar
Default 05 Trail Boss problem
Just got my 05 Trail Boss 330 a few weeks ago. I got to ride it for one day, absolutely loved it. Then I was out of town for a couple weeks. When I came back I was going to do the first oil change since I had about finished the first tank of gas (per dealer instructions). I went to take out the drain plug and it was VERY tight. Owner's manual calls for 14 ft-lbs torque when putting it in. So when I went to put the plug back in, it would tighten and then loosen. This kept happening. I removed the plastic splash shield to find that the block was cracked in a spot around the drain plug due to the factory (or dealer) over torquing the drain plug. I know it is impossible that I caused this damage as I had my torque wrench set to the 14 lb spec and it never clicked - so I never even got it that tight.
At any rate, what would you guys expect the dealer to do about this. I already took it back and they are fixing it. Sounds like they are replacing the block or something. They told me parts are on order and that I should get it back this week. Anything I should look for or be aware of? Any advice appreciated. Thanks! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 10, 2005 | 10:21 AM
2manytoys's Avatar
Sounds like your dealer is taking care of it. I dont think you need to do anything else. Now that you have a new 330 look at my pics to get some ideas for stuff to do. I have it decked out and its great.
Old Jul 10, 2005 | 01:11 PM
polarisbob's Avatar
I just bought a new trail boss to about 4 months ago a limited edition red one and i have put about 400 miles on it (give or take a few because i ride with my friends sp and it has a odometer) and it has a lot of power for a trail boss because it pulls the front wheels off the ground every time i gas it from a dead stop and it is bone stock other than wheels and tires but i want to put a clutch kit on it but i dont know who to get one from or how it will change my bike do you have any recomendations 2manytoys thanks.
Bob
Old Jul 10, 2005 | 02:08 PM
IronRanger's Avatar
here you go polarisbob,
http://www.erlandsonperformance.com/new/index.php
Old Jul 10, 2005 | 03:05 PM
shotaway's Avatar
There is one thing to check and that's to make sure they haven't patched it with JB weld. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 10, 2005 | 04:29 PM
Jason8225's Avatar
Great, thanks!
How does the plow work? I want to get one before winter hits. Do you need the winch for raising and lowering the plow? A friend of mine has a plow on his Sportsman and that's how it works. Also, since the Trail Boss is a 4x2 do you have any traction issues in ice/snow or do you use chains? Thanks again! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 10, 2005 | 04:33 PM
Jason8225's Avatar
Yeah, that certainly wouldn't be good. If it wasn't under warranty that might be something I considered myself though as a quick cheap fix. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 10, 2005 | 08:49 PM
2manytoys's Avatar
Jason8225
The plow works great. Better than I have ever expected it too. I do use chains and it helps alot. No traction issues and have never had a problem plowing deep snow. I use the winch for play but yes also for the plow.
Polarisbob
You dont need a whole clutch kit. Just get a new primary spring and it will move alot better. I highly rec a EPI pink (#patv8) or maroon (#patv10) spring. I have tried all kinds of springs and these are the only ones that really make a huge difference at all throttle positions. I gained 800rpm's on top and 7mph with the pink spring. I can beat stock 400sp's with my 330 and it is great on the trails. What do you mean by custom exhaust?
Old Jul 11, 2005 | 06:09 AM
polarisbob's Avatar
thanks for the info guys and
the custom exhaust was just a modified sportsman exhaust that i made but some guy rear ended the rear quarter on my trail boss when i was out riding last time and completely crushed it and mangled my exhaust, back rack, plastic and rear tire so i put my stock spark arrestor back on but atleast he paid me $350 bucks for the damage and some one stole my K&N air filter from my garage when i took i off so its stock again but i have 350 extra dollars to spend on it so i wanted to start with a clutch kit.
Bob
Old Jul 11, 2005 | 10:11 AM
Jason8225's Avatar
Originally posted by: 2manytoys
Jason8225
Awesome, thanks! That's very good to hear. I had my doubts about how well the plow would work.
Do you have a Polaris plow from the dealer or do you have some type of aftermarket one? May I ask how much the plow & winch ran you? It would be nice to have an idea of cost to know if I am getting a good deal from my dealer or not. Thanks for all your help! [img]i/expressions/face-icon-small-smile.gif[/img]
Frisky2050
Apr 9, 2020 11:19 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
