exhaust/coolent problem
Old Jul 11, 2005 | 06:36 PM
BigDare's Avatar
Default exhaust/coolent problem
well today, I when't to go take the sport for a ride and it wouldn't start, and I saw that there was white stuff coming out of the exhaust where the first two pipes come together, so I take off all the exhaust. the water whent all over. and theres seems to be a little hole on the top of the begining of the exhaust. IS THIS NORMAL!!! HELP!
thanx
Old Jul 11, 2005 | 06:43 PM
conig's Avatar
definatly doesn;t sound normal.
when you say hole in the exhaust do you mean the exhaust pipe, or in the jug below the head inside the exhaust port? there is alittle hole inside the port that acts as a decompression valve and this is suposed to be there.
either way I would think you need to weld either up. you may want to try and drain the crank case theres a drain screw on the bottom its the one closest to the clutches.
Old Jul 11, 2005 | 07:11 PM
BigDare's Avatar
the hole is the in the exhaust port, its spitin' that coolent out, should it be doing that
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
