Banshee Bogging Down?? Help
Old Jul 13, 2005 | 10:34 PM
johnny69's Avatar
Default Banshee Bogging Down?? Help
Just got my new 04 Banshee. I replaced the plugs and clean the air filter. Now it seems to start missing at mid-range RPMs. Once the power band kicks in its fine. Lower RPMs are alright too. The original owner was running different Spark Plugs. I replaced them with the standard ones the Yamaha deal gave me? Is it the plugs possibly?? Is so what plugs should I use??? If not the plugs what could it be??? All help is much appreciated.
John
Old Jul 13, 2005 | 10:49 PM
theCATman's Avatar
Is it piped?? If so it sounds like the needles are set too high. If not, then I'd say it was having the same problem with the orig. owner & instead of playing with carburation he used hotter plugs, which is not the answer. The Banshee should use the NGK BR8ES or B8ES.
Old Jul 13, 2005 | 11:12 PM
midnite's Avatar
Go to toomey.com, in their faq section there is a great explanation as to what is happening. In short, every banshee has a "rich zone" that can't be jetted out {due to motor harmonics vibrating the needle },and it's right before the cylinders are harmonized {right before the powerband}.
Old Jul 14, 2005 | 07:50 PM
Storj's Avatar
My blaster does the same thing it just bogges down when i shift from 3rd to 4th but it dosent happen if i am really winding it out
Old Jul 14, 2005 | 10:05 PM
atvbandit's Avatar
does it MISS ... or BOG at mid rpm's when u give it gas while bike is at neutral ?
Old Jul 15, 2005 | 11:44 AM
Storj's Avatar
I dont know it that was directed to me atvbandit but here you go anyway. My bike just boggs between 3rd and 4th but in neutral when i rev it it's fine
Old Jul 18, 2005 | 06:33 PM
atvbandit's Avatar
sounds like u could be MISSING under load ..... did you install fresh and properly gapped BR8ES ???
is the bike stock ???
Old Jul 18, 2005 | 06:36 PM
ltdbanshee03's Avatar
r u mixing your gas and oil correctly? how much oil did you put on your air filter?
Old Jul 18, 2005 | 07:25 PM
enFORCER's Avatar
Sounds like everyone is giving you things to check.... Check um all...
theCATman has a good question, is it piped??? If it is what main jets are you running??? Like theCATman said, drop the needles (raise the clip) and see if this has any affect....
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
