Thinking About New Exhaust
Thats the only down side to the AC is the Aftermarket accessory availability. I think HMF makes one in their Q1 series and FMF makes one in there Power line series, Supertrapp also makes one in thier IDS2 series. Any of these will work. Depending on how you are currently jetted will determine if you need to rejet. As long as you are jetted properly it shouldn't cause any additional wear on your parts.
I recommend save your cash and mod the stock muffler. Cut end off, drill 5 3/8 or 1/2 inch holes through all 4 or 5 baffles with a long drill bit, gut out the end cap, then re-weld back on. Works great, not too loud, and cheap. See photos.....click the little camera under my username.
Check out www.speedwerx.com we offer a full system for 04 and 05's that works awsome, it comes with insallation instructions and proper jetting as well.
