Thinking About New Exhaust
Old Jul 14, 2005 | 09:03 AM
CrashinIt's Avatar
Default Thinking About New Exhaust
What type of pipe do you guys recommend for an 04 650. Will i have to rejet it? Will a pipe cause any premature wear on any other parts?
Thanks Guys
Old Jul 15, 2005 | 04:51 PM
ttaylor's Avatar
Thats the only down side to the AC is the Aftermarket accessory availability. I think HMF makes one in their Q1 series and FMF makes one in there Power line series, Supertrapp also makes one in thier IDS2 series. Any of these will work. Depending on how you are currently jetted will determine if you need to rejet. As long as you are jetted properly it shouldn't cause any additional wear on your parts.
Old Jul 15, 2005 | 06:47 PM
DaveB's Avatar
I recommend save your cash and mod the stock muffler. Cut end off, drill 5 3/8 or 1/2 inch holes through all 4 or 5 baffles with a long drill bit, gut out the end cap, then re-weld back on. Works great, not too loud, and cheap. See photos.....click the little camera under my username.
Old Jul 15, 2005 | 07:02 PM
ttaylor's Avatar
Other then about a 10 lb weight savings your probably correct. I don't know if anyone has dyno'ed a comparison between an aftermarket exhaust system to the modified stock like you have done.
Old Jul 18, 2005 | 12:49 PM
Speedwerx's Avatar
Check out www.speedwerx.com we offer a full system for 04 and 05's that works awsome, it comes with insallation instructions and proper jetting as well.
Cole Hadden
Jun 15, 2025 09:05 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:43 PM
