425 magnum help
Old Jul 14, 2005 | 04:52 PM
raxxor's Avatar
Default 425 magnum help
i have a 97 425 magnum and it seems after about a hour of riding it loses all its low end torque if i let it cool down for like 10 min its back to normal. It seems like when it gets warm it loses all it low end. Any ideas?
Old Jul 14, 2005 | 05:02 PM
ATVnRocks's Avatar
If the tune up is good (ALL GOOD) u might be starting to wear the cam exhaust lobe off, tapet cover removal is needed to inspect.
Old Jul 14, 2005 | 09:27 PM
Polaridoo's Avatar
My old '96 425 used to do the same thing. I had done everything to it except cut the rev limiter wire and none of the other things fixed it - even the cam was perfect. If I had not sold it I would have cut the wire to the rev limiter and then started replacing ignition parts until I got it fixed.
Old Jul 14, 2005 | 11:27 PM
ftwflh's Avatar
Chech the air filter if you havent already.
Old Jul 15, 2005 | 06:08 PM
raxxor's Avatar
bump
Old Jul 15, 2005 | 11:48 PM
lslubecki's Avatar
Ditto.
Steve Lubecki
Old Jul 16, 2005 | 05:21 PM
Polaridoo's Avatar
Did you look into any of these items?
If these are OK:
1) Spark plug
2) Air filter
3) ETC adjust
4) Cam
6) Valve clearance
7) Carburetor / and boot
Then I would bipass the rev limiter. If the rev limiter doesn't fix it, then look to other ignition components.
Old Jul 16, 2005 | 05:50 PM
raxxor's Avatar
I checked my air filter and it looks pretty bad and i just gave it a tune up so we will see if the air filter was the problem. Thanks guys
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
